- 29 Sep 2011
- melee island
so, I bought a second hand iphone 13 pro max for someone as a gift, it has recently had a new aftermarket battery fitted, I got a USBC fast charger for it, to go with the supplied, unused lightning cable
I plugged it all in, and it seems fine, the phone is charging, but it is getting pretty hot, I'm using the phone at the same time as it is charging, should I be worried and rush togo get a OEM battery fitted by apple, or am I good to go?
I think that i'm going to charge the battery down some then try and fast charge it, and, as long as it charges, and doesn' t blow up then I'm going to give the phone away as the gift, and not worry about it
what do you think?
TIA
what do you think?
TIA
