old 5450 silent
Not really. It’s a 13 year old display adapter which was very basic at the time. Any iGPU from the past few years will blow it out the water.
It might be of use for an older system with no iGPU purely as a display output.
Stick it on MM or eBay I’m sure it would sell. It’s always better to try and sell them put it into landfill.
If this is your only spare GPU then I suggest you keep it. I have a spare 5850 in a drawer and a spare PC. If I suspect my main GPU has issues I can test it in my spare PC to make sure. If that works okay I can test my 5850 in my main PC. I can swap the PSU around etc. Every PC gamer should have two of everything unless they buy pre-builts with warrenty.
