Hi guys,
I find myself with a few spare bits from my old PC, and a little bit of cash burning a hole in my pocket, so I'm hoping y'all can help me find a good use for it
What I want to build: the smallest, quietest PC possible that will play blu-rays, and have enough HDD space to use as a network storage box.
Expected spec:
Core2Duo E4300 (@1.8GHz?)
2 GB of DDR2 (4x1 sticks available if the motherboard could hold them all)
ITX motherboard with nVidia 9300 (any alternatives?)
HDD: have a 3.5" but open to buying a new 2.5" if required
Case: something cheap and cheerful like a Lian Li Q07B
What I don't know and would appreciate help with :
1) is this thing going to be able to play blu-rays or is it just too slow?
1a) if too slow, can it be overclocked to the task within an ITX enclosure without getting too hot? Will reliably run @2.66 with good cooling.
2) is 2 GB memory going to cut it if I stick Windows 7 on it? Won't be used for games, just media playback and file storage.
3) what are the odds it will idle cool enough that speedfan (or similar) can safely turn off the fan when it's doing nowt? Would love this thing to be motion-free when not under load.
4) need to pick a cooler - I am assuming my zalman 9500A will not fit in an ITX case, although it would be lovely if it did!
Thanks in advance
Expected spec:
Thanks in advance
