The property we are in the process of buying needs a fair bit of work, one of those items is removal of an old Baxi boiler, that is vented into a dedicate chimney. There is a full chimney stack visible in the loft and roof, with some visible in a corner of a room on the first floor, but as seen on this image, there is no full breast/exposure in the kitchen. Just wondering if anyone is familiar with the way the chimney might be supported/work for this?
We would ideally like to remove the bottom section from the kitchen, ready for a new kitchen and boiler install, but looking for some direction. From reading it also sounds like with this sort of setup, there is often use of cement containing asbestos as part of the boiler flue to chimney connection?
Thanks in advance
Thanks in advance
