Hi there.
Long story; I went to install a new HDD on my older build which is:
PowerColor HD 7850 2048MB GDDR5
Intel Core i5-2550K 3.40GHz (Sandybridge)
Gigabyte Z68XP-UD3P Intel Z68 (Socket 1155)
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2)
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9)
Gelid Tranquillo CPU Cooler
+ 3 other SATA HDDs.
When I plugged the new HDD in, (power off etc) I booted up and it posted. However for some reason the motherboard wouldn't detect any of the HDD's in bios and wouldn't boot.
I tried unplugging some etc and just having the SSD plugged in.. still wouldn't recognize the in bios or any of the other HDDs (individually or collectively).
I left it a while to go google on my laptop. I came back and it then refused to post at all. (power was on, fans would work but not POST).
I did the usual and disconnected everything, took the motherboard off the case (last time I had that the mobo was shorting on the case) and just connected one stick of ram, the CPU + cooler and the grfx card whilst it was on a non-conductive pad. (also reset the bios).
Still wouldn't post (same thing, power light on, fans work, but wouldn't post).
Subsequently I've purchased a new build:
Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Black
Corsair Builder Series CX 750W Modular '80 Plus Bronze' Power Supply (CP-9020061-UK)
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
The new build does exactly the same thing! Powers on, fans go and won't POST.
I'm at my wits end as I can't identify which component is faulty...
Any ideas on other things to try?
