Hey,
I have an old Corsair HX520W which is around 10yrs old. It's a decent PSU even though it's an oldy but I have a question regarding power x2 3070 and PCI-E risers (it's a 2nd PSU for the GPUs and risers only)
It comes with x2 6-pin ports (with 6+2 cables) then a selection of standard Molex ports.
It does 520W at 80-85% efficiency and has x3 12V rails that can provide 480W (40A). The 3070s have a TDP of 220W each (440W total), then there's the riser cards to consider, but the 3070 cards will be undervolted to around 120-130W in actual usage.
Could this be used to power x2 3070 GPUs in a configuration like so:
3070 1 - 8-pin 1 = 6pin - 6+2pin cable
3070 1 - 8-pin 2 = Dual Molex - 6+2pin cable
PCI-E Riser 1 = Molex - Molex
3070 2 - 8-pin 1 = 6pin - 6+2pin cable
3070 2 - 8-pin 2 = Dual Molex - 6+2pin cable
PCI-E Riser 2 = Molex - Molex
Thanks
Thanks
