I'm not sure if this is the right forum, but...
New build in sig, what I would like to do is to fit the old HDD from the previous build so I can retrieve a few files and then format it for future backups.
What I'd like to know is..
A) The old HDD is a SATA like the new one, is this ok? New one is in SATA 0, where should the new one go?
B) The old HDD has XP installed on it, along with an anti-virus and firewall. Will these try and boot up/start up causing conflicts? (New build has Vista 64 installed) I'm guessing that if Xp doesn't boot then the firewall and anti-virus will not attempt to start..
C) Is it even possible to format the old one from vista?
Phew...sorry about my n00bness..
