Old I7 920 go for 6700k or 5930
5830K is almost entirely pointless unless you run at least 3 nvidia cards AND additional PCI-E stuff such as sound cards, PCI-E storage etc, or 4 nvidia cards.
6700K is pointless, skylake is a complete flop.
Doesn't matter for AMD cards as they allow x4 bandwidth crossfire, but nvidia don't allow x4 SLI.
5820K or a 4790K. You won't notice any difference in gaming, in fact the 4790K might be a bit better as it clocks higher, would also mean you save money on the motherboard and the RAM too. DDR4 RAM so far has no benefit over DDR3 RAM, at least unless you buy the stupidly expensive DDR4 kits, but even then the difference is very small.
Personally I would go with the i5 4690K over the 4790K, save you another £100 for pretty much no difference outside of multi-threaded benchmarks. Although if you are running 3/4 GPU's at a high resolution (1440p+, including multi-monitor), or 2 GPU's at a low resolution (1080p) I would recommend the i7 as the CPU usage is quite high.
I only just avoid CPU bottlenecking with my setup at 4K in BF4 64 player games, but that is an extreme example, most games don't come close to using the CPU that much.
If you use nvidia cards the CPU overhead is also lower so I really wouldn't worry about it then.
I have just gone from a i7 930 to a 4790K :D done it on a cheap as well , havent played any games on it yet as im awating for my water cooler.
The truth has been spoken! I totally agree with you. :D
5930 if you want it to last years to come! But only if u need the 40pcie lanes, if not 5820k is best bang for buck!
5930k if you have lots of money to spend. And it should last you a long time. A lot longer than a 6700k would.
But as mentioned above, if you are on a budget and would like to save some money. You won't go wrong with a 4790k
Go for the 5820k some games already benefiting from more than four cores/eight threads. The 4790/6700k will generally overclock better (300-500mhz) dependant on silicon lottery and cooling but the 5820 will only be a few fps behind in current games that don't benefit from more cores and will totally dust them in games /apps that can benefit from more cores so imo better long term buy
I've been in a similar boat. Skylake feels totally underwhelming and I'm Pretty sure for a totally new gaming build I'm now going for x99 and a 5930k. I want it to last, don't want any compromises and the more cores the better for future games. I'm unlikely to use more than 2 graphics cards ever, but even so I want max lanes....
As I understand it, On a 5820k and if using 2 graphics cards, one card will run at x16 and one at x8. Unless you can lock both cards to the same x8 and x8, I may be naive but I can see this possibly causing issues!
5930k removes any such worries. I'm also thinking that the true next gen graphics cards - pascal etc may benefit more from pcie3 x16. Only maybes granted, but for only £120 more (when I'll be spending shed loads anyway on a whole build) I think I may as well go for 5930k.
5930k is best bet. DX12 will make use of extra cores in gaming apparently. I have bought a 5930k and it goes to 4.7 at 1.27v and I haven't really pushed it yet as I am about to re build my computer.
"6700K is pointless, skylake is a complete flop."
It's just not true !
Skylake outperforms just about every other processor on a single core basis. It might outperform them on two or even four cores, but the test results just aren't available.
When are you going to run an application which uses 6 cores at once?
DX12 - overhyped probably is never ever going to use more cores than 99% of gamers have access to - 4 at most.
Most games only use a single core, a few use a couple and although more might be in the pipeline it's still a long way off.
