Old laptop freezing after 30-40 minutes
13 Sep 2006
Using an old Dell laptop to run some presentation software. Now freezes 30-40 minutes after switching on. Works after a reboot. What do you reckon?
Faulty RAM?
CPU overheating?
Something else?
Appreciate your comments
Had the same problem as your are having. Turns out one of my DIMM slots has burnt out.
I suggest taking out the RAM, and trying it in a different slot, if you can, try different (but compatible) RAM aswell.
I suggess opening it up and giving it a good clean, sounds like overheating to me.
Though faulty ram could also give you that problem, download an iso image of memtest(or a linux live disc) and run it and see what it finds.
