old laptop upgrade options....
5 Jan 2005
Engerland :)
ok while my pc is down using this for web etc.
im gonna throw it out the window!
I understand I can put in 2gb ram... it has 512 + 256 at the mo.....
and the drive is a 30gb effort....
if I find 2 gb ram... and update the drive... whats the fastest drive I can put in there..... ?
and is running Windows XP...
is there a better operating system for this measly spec!
laptop seems to be this one..
http://uk.computers.toshiba-europe....e.do?PRODUCT_ID=94118&DISC_MODEL=1&service=UK
2 x 1gb ddr will cost you around £70
cheapest new ide hard drive is around £40 for 160 gb 5400 rpm
You might be able to upgrade the cpu to a pentium 4 variety
As for the os i would probably stick to xp, vista tends to crawl on older tech.
cool .. will keep an eye out in the MM market ... might pick up a couple of bargain bits...
Yeah not gonna spend loads - its just a backup laptop...spent too much on my desktop machine.
But yeah will keep eyes open.... So 7200 rpm probs.... 2.5 inch ide to fit these things yeah?
I gather little ssds can't go in here without sata option?
yeah 2.5" ide will fit, not sure if you can get ide SSD but i think its doubtful.
