Old laptop WiFi issues
10 Sep 2022
essex
Hi,
I have an old laptop, circa 10 years old, it's still fine for surfing the net and Microsoft office applications, and the wife likes to use it, I've a recently built desktop which I tend to use.
Since going to full fibre broadband and the new router is a Linksys velop spnmx55, the laptop no longer sees the WiFi signal.
I've split the signal so there is a 2.4g and a 5g circuit, the laptop can usually only see 2.4g, I've a Honeywell smart heating system that also needs the 2.4g signal and that picks it up no problem.
The laptop has a realtek RTL8723AE 802.11n chip in it, it seems to pickup my neighbours WiFi signals.
Is the laptop just old and crap and can't communicate with the router?
Should I get a usb WiFi dongle for it?
You can either get a USB dongle, or depending on the age/design of the laptop, may be able to replace the internal Wifi card with a newer model (e.g. one that supports at least 802.11ac)
Ok thanks , so it's just a fact the card is too old for the later router.
Other than usb ports the laptop has no other means of upgrading,
Hi,
The wifi module might be replaceable. What laptop is it?
Bought the USB dongle, sort of works, the 2.4g is stupidly slow, and it won't connect to the 5g, having Googled seems the tp link nano ac600 I bought everyone has the same complaints over.
So I'll send this one back and try for something else
Most usb WiFi dongles are rubbish - the majority use realtek chips that tend to be terrible.
An upgrade Intel based internal WiFi card is the best way forward, but obviously requires some technical skill to take a laptop apart
Might be worth changing the the wireless channel on the router. There are 13 possible channels, but some kit only supports up to 11.
Another option is if you still have your old router, you might be able to set it up as an access point. And connect it to your new router.
