Hi all
I am running Ubuntuu Dapper (2.6.15.27) on an old AMDk6 and trying to get the modem working. Its an old Motorola SM56 PCI. I have run the scanModem utility (see below) but not sure ui understand it - i think it is telling me there are in fact no drivers - is this correct?
If it is possible what is my next step?
many thanks
Diss
Only plain text email is forwarded by the [email protected] List Server.
Do use the following as the email Subject Line:
SomeName, YourCountry Ubuntu 6.06.1 LTS kernel 2.6.15-27-386
This will alert cogent experts, and distinguish cases in the Archives.
YourCountry will enable Country Code guidance.
Occassionally responses are blocked by an Internet Provider mail filters.
So in a day, also check the Archived responses at http://www.linmodems.org .
Local Linux experts can be found through: http://www.linux.org/groups/index.html
-------------------------- System information ----------------------------
Ubuntu 6.06.1 LTS
Linux version 2.6.15-27-386 (buildd@terranova) (gcc version 4.0.3 (Ubuntu 4.0.3-1ubuntu5)) #1 PREEMPT Sat Sep 16 01:51:59 UTC 2006
scanModem update of: 2006_November_07
USB modem not detected by lsusb
Modem or host audio card candidates have firmware information:
PCI slot PCI ID SubsystemID Name
0000:00:09.0 1057:5600 1057:0300 Communication controller: Motorola SM56 PCI Modem
Modem interrupt assignment and sharing:
12: 16297 XT-PIC ohci_hcd:usb1
--- Bootup diagnositcs for card in PCI slot 0000:00:09.0 ----
=== Finished modem firmware and bootup diagnostics section. ===
=== Next deducing cogent software ===
For candidate modem in PCI bus: 0000:00:09.0
Class 0780: 1057:5600 Communication controller: Motorola SM56 PCI Modem
Primary PCI_id 1057:5600
Support type needed or chipset: Motorola
Vendor=1057 is Motorola with some service provided through
vendor=11d4 Analog Devices Inc. Drivers are available for VERY FEW 2.4.n kernels
http://www.motorola.com/softmodem/driver.htm
and for 2.6.n only a Fedora 2.6.9-1.667 at
http://www.linux-xp-brasil.com.br/sm56-06.09.05-1-fc3-2.6.9-1.667.i686.rpm
A driver is NOT available for this kernel 2.6.15-27-386.
Motorola seems to be only providing source code to some equipment mnaufacturers,
who may provide particular compiled Linux drivers with their products.
See details in Motorola.txt
---------------- end Motorola section ------------------------
Completed candidate modem analyses.
The base of the UDEV device file system is: /dev/.udev
The kernel was compiled with gcc version 4.0.3 and a compiler is not installed
If compiling a modem driver proves to be necessary, one of the two procedures must be followed.
If not yet on the Internet, put the Dapper install CD in the drive
Open a terminal and therein:
$ sudo apt-get install gcc-4.0 make
Additionally the package linux-headers-2.6.15-27-386 must be downloaded.
Go to http://packages.ubuntu.com/ and search for linux-headers-2.6.15-27-386
After downloading, it can be installed with:
$ sudo dpkg -i linux-header*.deb
Or alternatively if online through Ethernet do:
$ sudo apt-get update
$ sudo apt-get install build-essential
will do all the necessary installations mentioned above.
In either installation case, set a symbolic link which will be expected later:
$ sudo ln -s /usr/bin/gcc-4.0 /usr/bin/gcc
After check with:
$ ls -l /usr/bin/gcc*
which should display:
lrwxrwxrwx 1 root root 16 2006-07-09 21:53 /usr/bin/gcc -> /usr/bin/gcc-4.0
-rwxr-xr-x 1 root root 93584 2006-04-20 18:22 /usr/bin/gcc-4.0
-rwxr-xr-x 1 root root 16245 2006-04-20 18:13 /usr/bin/gccbug-4.0
Kernel-header resources needed for compiling are not manifestly ready!
If compiling is necessary packages must be installed, providing:
gcc-4.0 make linux-headers-2.6.15-27-386
Checking pppd properties:
-rwsr-xr-- 1 root dip 257720 2006-07-05 14:00 /usr/sbin/pppd
In case of an "error 17" "serial loopback" problem, see:
http://phep2.technion.ac.il/linmodems/archive-sixth/msg02637.html
To enable dialout without Root permission do:
$ su - root (not for Ubuntu)
sudo chmod a+x /usr/sbin/pppd
or under Ubuntu related Linuxes
Checking settings of: /etc/ppp/options
asyncmap 0
auth
crtscts
lock
hide-password
modem
proxyarp
lcp-echo-interval 30
lcp-echo-failure 4
noipx
Read Modem/YourSystem.txt concerning other COMM channels: eth0
Which can interfere with Browser naviagation.
Don't worry about the following, it is for the experts
should trouble shooting be necessary.
Checking for modem support lines:
/device/modem symbolic link:
slmodemd created symbolic link /dev/ttySL0:
Within /etc/udev/ files:
/etc/udev/rules.d/60-symlinks.rules:# Create /dev/modem symlink
/etc/udev/rules.d/60-symlinks.rules:KERNEL=="ttyLTM[0-9]*", SYMLINK+="modem"
Within /etc/modprobe.conf files:
/etc/modprobe.d/alsa-base
ptions snd-atiixp-modem index=-2
ptions snd-via82xx-modem index=-2
/etc/modprobe.d/blacklist-modem:# Uncomment these entries in order to blacklist unwanted modem drivers
/etc/modprobe.d/blacklist-modem:# blacklist snd-atiixp-modem
/etc/modprobe.d/blacklist-modem:# blacklist snd-via82xx-modem
Within any ancient /etc/devfs files:
Within ancient kernel 2.4.n /etc/module.conf files:
--------- end modem support lines --------
many thanks
Diss
Ubuntu 6.06.1 LTS
After check with:
asyncmap 0
auth
crtscts
lock
hide-password
modem
proxyarp
lcp-echo-failure 4
noipx
ptions snd-atiixp-modem index=-2/etc/modprobe.d/alsa-base
ptions snd-via82xx-modem index=-2/etc/modprobe.d/blacklist-modem:# Uncomment these entries in order to blacklist unwanted modem drivers
