Old PC Help
31 Jan 2007
Hello,
I ahve an old pc pentium 3 and so on which I ahve formatted the drive and reinstalled xp. (It had xp on before) and since the reinstall the entire system just freezes at random times. Cannot seem to find a trigger point or operation to do it, it is just random. Can anyone try and help give any ideas to fixing this problem?
Thanks
Neil
The component manufacturers web site is normally the best place. Is it a self build or a off the shelf unit ? Identify the motherboard/chipset and then do the same for the GPU etc. XP's bundled drivers are somewhat outdated by now (it's circa 6 years old!).
