Old PC mixing memory
6 Sep 2016
I've got a PC with 8GB of memorg, 2GB sticks x 4. What settings should I enter in BIOS, I have left everything at auto just wondering if it's ideal settings
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Module Manufacturer(ID) OCZ (7F7F7F7FB0000000000000000000)
Size 2048 MBytes
Max bandwidth PC3-8500F (533 MHz)
Part number OCZ3P1600C6LV2G
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-12-19 @ 380 MHz
JEDEC #2 6.0-6-6-14-23 @ 457 MHz
JEDEC #3 7.0-7-7-16-27 @ 533 MHz
JEDEC #4 8.0-7-7-16-27 @ 533 MHz
DIMM # 3
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Module Manufacturer(ID) Corsair (7F7F9E0000000000000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CM3X2G1333C9D
Manufacturing date Week 20/Year 09
Number of banks 8
EPP no
XMP no
AMP no
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 7.0-7-7-19-27 @ 518 MHz
JEDEC #3 8.0-8-8-22-30 @ 592 MHz
JEDEC #4 9.0-9-9-24-34 @ 666 MHz
Northbridge AMD 870 rev. 00
Southbridge AMD SB850 rev. 40
Bus Specification PCI-Express 2.0 (5.0 GT/s)
Graphic Interface PCI-Express 2.0
PCI-E Link Width x4 (max 4x)
PCI-E Link Speed 5.0 GT/s (max 5.0 GT/s)
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual, (Unganged)
Memory Frequency 535.7 MHz (3:8)
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 20
Bank Cycle Time (tRC) 27
Command Rate (CR) 1T
Uncore Frequency 2008.8 MHz
From CPU-Z.
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Manufacturer AuthenticAMD
Name AMD Athlon II X4 610
Codename Propus
Specification AMD Athlon(tm) II X4 610e Processor
Package Socket AM3 (938)
CPUID F.5.3
Extended CPUID 10.5
Brand ID 8
Core Stepping BL-C3
Technology 45 nm
TDP Limit 44.0 Watts
Core Speed 2410.6 MHz
Multiplier x Bus Speed 12.0 x 200.9 MHz
Base frequency (cores) 200.9 MHz
Base frequency (ext.) 200.9 MHz
HT Link speed 2008.8 MHz
Stock frequency 2400 MHz
all you need ot do is put the slower stick in slot one and you system will match its speeds to the others but running all at auto it make no differance at all so you good
