Old PC wont boot
Permabanned
20 Oct 2012
The PC was working 2 weeks ago until i took the HDD out of it.
I have now put my HDD into it and everytime it gets to the windows logo it will restart?
Ive tested the ram both by taking out 1 at a time and by memtest.
Ive tried last known config and re plugged everything back in.
The 3 options i have now is the PSU, MOBO/CPU or the HDD.
Im not gonna wipe this HDD and try a new install as i know it works.
The MB green light comes on so i know its getting enough juice.
Another problem is monitor wont come on sometimes so it could be the graphics card?
I can try test another card tomoz to see if thats the problem but it worked fine like 2 weeks ago which is why im muffed?
Ive chkdsk /f but no problems.
try running an ubuntu live CD, this should tell you if its a hardware or OS based issue, if the cd runs up ok then just do a fresh windows install
