If you can manage to pry the DVD panel off, you can force the tray out by inserting something thin and sturdy under the tray and moving from left to right. But if its totally broke already you might as well break out a screwdriver... or just go 'Hulk smash!'
Yep if you take out the 8 screws from the bottom of the PS2, and then turn it over, there is a plastic cover that covers the PS2 drive tray (has 4 screws holding it on iirc) remove that and theres your disk
