- 15 Mar 2004
- Oxford
Hey guys,
I run two monitor on my machine a Samsung Syncmaster p2450 which is my main screen.
Then a Samsung Syncmaster 2033 which i use to keep apps open like teamspeak and cpu temp monitors gpu temps etc etc
Now i went for a bath a while ago and both screens was on fine no problem.
I cam back and the 2033 screen was very dark i could kinda make out what was on but i had to squint.
Now its totally black. It is on cos the blue light is on it has input cos its not flashing. If i turn the monitor off and on again it lights up with what should be on it for a second then goes dark again. I've swapped cables over to make it the main monitor same thing, i used the D-sub socket instead of the DVI one and still the same thing.
Any ideas or is it borked ?
Thanks
Thanks
