Old School card....
14 Nov 2012
Chesterfield
I need to get hold of a RADEON X300 Low Profile which has a VGA & DVI port. I've been googleing, but not really finding anything. I think the low profile is limiting the options.
If I cannot source one of these cards, can you advise what alternative replacement would be suitable? Needs to have DVI & VGA.
This is to go in a Philips Freeline slim tower. It's not mine, but someone is asking a favour.
Can always get something like This.
Was my first GPU, got like 30 Frames in minecraft vanilla, so not great, but it will do.
If he didn't mind B Grade he could get something like This.
Both GDDR3, Nvidia one has higher effective clock and memory, Have a little comparison, just you can get some real cheap B Grade ones.
They are single slot, but the heatsinks might be a bit larger.
Thanks, I'll pass the details on. No gaming will take place, will simply be to use dual screen at home. I'm not sure of the case limitations, but if the profile is the same as the original, should be fine.
