OLD SCSI / ASPI LAYERS ( HELP! )
18 Oct 2002
Behind you... Naked!
I need to get a SCSI Card up and running in MSDOS with the ASPI layers done.
Im kind of failing to do it.
I have a few cards, Avansys, Adaptec, LSI etc, btu one that I have also, is a DOMEX 3194
Now, this Domex I still have the original Floppy Disk for, plus, I have found some more drivers on the net, and so, its this, that I have been toying about with.
However, I just cannot get the ASPI Drivers installed?
Putting things simply, it seems that all it needs is the following :-
DEVICE=C:\ASPI3194.SYS
to be present in the CONFIG.SYS file.
But it keeps tellign me that its failed.
I have tried various other files and various other things in the CONFIG.SYS such as HIMEM and so on, but nothing seems to help me?
Is there any particular way that I need to do this?
As I said, its got to be done under MSDOS and so, Im using 6.22
Thanks.
