Old SSD in enclosure not shown
9 Jan 2009
isle of wight
I'm racking my brains and I can not figure this out
I have an old SSD (Samsung SM951 MZ-HPV5120 512gb) I want to retrieve some data from, nothing too important just some game saves.
I have brought a ugreen m.2 NVMe/SATA SSD enclosure from the rainforest.
I have plugged it into my laptop and can not access it
In disk management it is there but if I try to initialise it.
I get the incorrect function error with both MBR & GPT.
Is disk part I can select the disk but it comes up as the chip (RTL9210B-CG) with no volumes.
Googling has mostly just led to guides from data recovery companies that ultimately just want me to buy a licence.
I have updated the firmware on the enclosure and still nothing.
Is there any way with disk part/ CMD I can get it detected
Best I can tell is that the SSD isn't compatible but looking at specs I can't work out why it wouldn't be unless I'm missing something. If that is the case does anyone have any recommendations on an enclosure that could be? They helpfully refunded the entire order when my laptop stand was missing so have some credit to my account to buy one that works.
Thank you for any help
Think I have finally found an answer.
Seems Samsung made 2 versions
NVMe version
AHCI version
It seems I have the AHCI version which isn't compatible with the SATA or NVMe protocols. Looking around it seems external enclosures don't exist for the very short lived AHCI standard.
Could I plug it in to an internal motherboard m.2 motherboard?
Any other suggestions on how to access the data?
Try plugging it back into the Pc and see if it shows up that way.
Unfortunately, the pc it's from the water-cooling pump broke so I dismantled it and sold it all to help fund my new PC which is currently all on back order.
Only pc I have access to at the moment is a old sandy bridge pc that doesn't have an m.2 slot
Can't even find any documentation to say of B850 even supports this standard.
I didn't know PCI-Express drives that use AHCI existed, weird, in the anandtech article they mention some boards that it worked with, but I'd be worried that more modern motherboards would have dumped support for these drives.
Since you don't want to boot from it, theoretically you could try an adapter that lets you plug the M.2 drive into it and then into a PCI-Express slot on the motherboard, but you might have the same issue as the enclosure.
I remember when I brought it around 10 years ago, it one of the faster drives around at the time.
Seems to be a small number of mostly OEM Samsung drives from what I'm seeing. I would doubt if when it arrives my B850 board will support it.
I have just found for £2.99 at the rain forest place with no reviews, an adapter for PCI-E that claims to support it. Will give it ago.
I note in your OP that you were trying to initialise the drive. If you do that you will lose all your data.
