Ok my old system is this:
Antec P180
Asus A8N-Sli deluxe
AMD Athlon 64 FX-55 CPU
Sli Asus 7800 GTX
2 gig memory
Windows xp Pro
Now the story goes that my fans (stock Antec 120mm and Northbridge fan on the mobo) are on their way out. So, I need to replace them. At the same time I want to replace the PSU and shortly I will throw in a HD 5850 to replace the Sli 7800 GTX cards (yes I know they are overkill but I have the card spare).
Now, The 120mm fans are to be replaced with this:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-XI&groupid=701&catid=57&subcat=4
And the Northbridge fan with this:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-029-SY&groupid=701&catid=57&subcat=818
And the PSU with this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-019-CS&groupid=701&catid=123&subcat=1084
I don't know my way around the computer and I need to know if I have the right plugs, wiring etc etc ... is there anything else I need to order to make these fit?
Antec P180
Asus A8N-Sli deluxe
Sli Asus 7800 GTX
2 gig memory
Windows xp Pro
