Old tablet with stylus for drawing suggestions
18 Oct 2002
Nr Colchester, Essex
Hi Everyone,
I am after some insight into older tablets(or Laptops) that had a stylus e.g. a Samsung S Pen. I have had note phones since the note 2 and the children like stealing them to use apps such as Pen Up. I would like to get them a larger tablet to use but I am struggling with which tablets actually included a stylus or didn't come with one but are compatible. For example I read that the Galaxy Tab A was available with one but I haven't found any evidence of that, so if it is compatible then which S pens is it compatible with?
Really I am looking to spend as little as possible with them still being useable and would love to hear some suggestions. Requirements are basically an ~8-10" screen, Stylus and a Drawing app. It's prefrable the stylus lives inside the device but not essential.
Thanks!
Hi
I'm looking for something simmlar but want as my son loves drawing . The s6 lite is about £250 and comes with an s pen .
Have you found anything cheaper?
Someone has a Tab S7 FE for sale in MM.
Yeah, you're basically looking for a Tab S6 Lite. There's the older version and the 2022 version. The orginal version will be cheaper.
All other options are old and they come to near enough the price of the s6 lite, so you might as well get that.
