Yes the cables Can be done better , i will need the right size cables ,some longer ones to go around the back of case & PSU ,
The Sata cables can be hidden or hardly seen if there was a hole near the end of the motherboard & then could use shorter sata cables ,
not to fussed as there is only a little side window. I may drill a hole but nothing too crazy as i did to my Metis Case Build
I wonder if Overclockers can get stock of a Blue-Ray\DVD Slot Load Optical Drives for Raijintek Styx Case.
Loads of Brands out there ,Then again i guess how much of a demand on the drives as the Blu-ray part be just be for watching blu-ray movies &
be big price tag & would be cheaper to use a small USB External Bluray Drive.
Ah it still would be nice to have a slot drive that do all the formats in the Raijintek Styx Case.
*Changed PSU to "Silverstone Strider SFX 600W Fully Modular '80 Plus Gold' Power Supply"
*Modded the Lian Li PT-FN07 Fan Control with a old thermaltake PCI bracket
* Added a cable with a slim line power connector from the "Silverstone short cable set"
*Added a 2nd Coolermaster BC 120mm fan at top
* Did some Cable Tidying
