Old timer overclocker sons gaming pc build advice
31 Jan 2003
Lincoln LN3
Hi fellas,
Ive been out of the p.c/overclocking scene for a long while now while i've been doing family stuff etc.
Now my son has turned 13 he wants a gaming p.c.
Me being me wants to dive in and get the best components etc but i've got to realise that this is his first p.c.
So, budget-wise i've got £500-600 and this is to include speakers, keyboard/mouse and minimum 24" monitor.
Spec-wise, well really the best for gaming.
Not fussed if it's intel or AMD, Radeon or Nvidia.
My knowledge is just fine to build it myself, my background is water-cooling and Mach II cooling so i'm pretty well versed.
All comments and suggestions welcome :)
Given that a monitor will cost you ~£100 as will Windows, you're looking at £300-£400 for the PC itself. That's not a lot. Can your son get a cheap educational license for Windows from his school?
Thanks for taking the time to quote that system.
Assuming i get the monitor before the tower and i had £500-£600, what would you recommend??
Lets say £500-£600 on the tower itself to make it more realistic.
Nice!!
Do you rate the Intel i5 bundles over the AMD bundles??
Yes i do, the i5 is excellent and that bundle is great value . AMD lag behind not so much in the value oriented cpu's but high end .
Intel has far better single core performance and as most games only use 1 or 2 cores they dominate.
Gaming an I5 quad core is the way to go.
Fantastic, this is the information i need.
So best bang for buck is the i5-4440
Same question for the graphics then please, Radeon vs Nvidia (runs away and awaits fanboys)
I appreciate the help fellas
Nice one fellas, you've given me a great place to be starting.
I'm sure i've got a decent modular PSU still which reduces the costs further.
Is it worth upping the onboard memory for the graphics? I'm guessing the games nowadays use a good chunk of onboard memory as well as the GPU so bigger is better
I'm in a similar boat and I have gone for a few choice second hand parts from the members market and some new bits. Kept the cost down a little and have ended up with a better pc for my son.
