a few friends and myself want to relive our lan gaming days.
we are looking at
medal of honour
quake
unreal
revolt
crimson skies
now none of us want to lug our desktops around anymore so we are looking at the mini pc market from sticks to mini boxes.
the ones we are eyeing the most are the Z83 mini pc
specs
Specification
System Config.
Model Z83
OS Windows10
CPU Intel Atom,Quad Core 64-bit 1.44 GHz x5-Z8300 Processor (2M Cache, up to 1.84 GHz)
GPU Intel HD Graphics
RAM DDR3 2GB
ROM Windows(C
32GB
Expand Memory SD Card (Support 128GB)
Performance
Threads 4
Scenario Design Power (SDP) 2 W
Processor Base Frequency 1.44 GHz
Burst Frequency 1.84 GHz
Instruction Set 64-bit
Advanced Technologies Intel Identity Protection Technology
Communication
Ethernet 1000Mbps LAN
WIFI IEEE 802.11a/b/g/n,2.4G+5.8G
Antenna Built-in antenna for WIFI
Bluetooth BT 4.0
Interfaces
I/O 2*Standard USB2.0 Port
1*Standard USB3.0 Port
1*HD A Type Port
1*SD Card Slot
1*Headphone Microphone Jack
1*RJ45 (1000Mbps network connection)
1*Power Button
1*Power LED with two - color
1*DC in Port
Others
Language Multi -language
Work Environment 5°C -- 35°C, 30%--90% Humidity
Storage Environment (-20°C -- 60°C),10%--90% Humidity
Power Management
Adapter DC12V 2A(100-240V,50/60Hz)
Dimension
Product Dimension 11.95*11.95*2.40cm
Product Weight 193g
Package Dimension 13.00*12.30*8.50cm
Package Weight 524g
will this little box have the power to play them.
now will i need to put win 98 or xp on it for them to work or can win 10 do it.
i did try one game on win 8 a while back and had to install ipx wrapper to get ipx/spx to be able to lan game.
thank you for any help.
we are looking at
medal of honour
quake
unreal
revolt
crimson skies
specs
Specification
System Config.
Model Z83
OS Windows10
RAM DDR3 2GB
ROM Windows(C
Performance
Threads 4
Communication
Bluetooth BT 4.0
Interfaces
1*HD A Type Port
1*SD Card Slot
1*Power Button
1*DC in Port
Others
Power Management
Dimension
Product Weight 193g
Package Weight 524g
