I am using a Basic Wordpress theme called Manifest as a framework for a site I am working on.
The theme is great because its simple and very easy to modify. The only down side I have found is that it doesn't use the Wordpress Custom Menu System.
What is the quickest/easiest way to convert the theme to support the Wordpress Menu System.
I only have 1 menu on the site at the top of the page. The current code for the Menu is as follows:
The Wordpress Theme is so basic that it doesn't even have a functions.php file so I am guessing I will need to create this file too?
Thanks in Advance!
Code:
<div id="mainNav">
<ul>
<?php wp_list_pages('title_li=&depth=1'); ?>
</ul>
</div>
Thanks in Advance!
