11 Feb 2014 at 12:39 #1 Wayn0r Wayn0r Soldato Joined 14 Nov 2002 Posts 5,715 Can anyone tell me whats the minimum spec/age of Mac Pro to run twin monitors with extended display, or even triple monitors? thanks
11 Feb 2014 at 13:28 #2 Lowe Lowe Soldato Joined 18 Oct 2002 Posts 6,224 Location Newcastle Under Lyme Depends on the GPU - it was an optional extra to have extra gfx cards or more powerful ones with extra outputs...
11 Feb 2014 at 13:31 #3 Wayn0r Wayn0r Soldato OP Joined 14 Nov 2002 Posts 5,715 Lowe said: Depends on the GPU - it was an optional extra to have extra gfx cards or more powerful ones with extra outputs... Click to expand... Cheers andy, is it easy enough to add an extra card?
11 Feb 2014 at 14:07 #4 Lowe Lowe Soldato Joined 18 Oct 2002 Posts 6,224 Location Newcastle Under Lyme Yeah, basic PCIe - just drop it in like a PC.
11 Feb 2014 at 22:31 #5 Skyboat Skyboat Soldato Joined 13 Jan 2005 Posts 3,375 Location South West Any Mac Pro that can use a discrete GPU should do.
