Oldskool Overclocking - ish
21 Sep 2005
Bradley Stoke, Bristol
Got myself a Socket A XP1700 thoroughbread from the MM. More used to AMD64 systems, so there may be some errors in my techniques.....
Been putting the chip through its paces a little.
Not sure its working as well as it should be. Specs are as follows:
XP1700 + Akasa XP3200 cooler
Abit NF7-s (revision 1.0)
512MB DDR400 Corsair
NVidia FX5200 (passive cooler)
*cough* low quality 300W £7 psu *cough*
Wasn't planning on pushing it very far with this powersupply, but got carried away anyway.
I pushed the fsb up to 166 (333) and set the unlocked multi to 12 (cpu @ 2GHz). Ram is running 1:1 at 2-2-2-6 (DDR333)
Havent taken it further as I dare not.
I ran SuperPi on it --- Does that seem about right?
THe thing that is making me think something is wrong is a combination of very slow boot times running windows 2000, takes about 3-4 minutes to get to login screen on a base install (probs just the slow harddrive I guess....)
More so running UT2004 this rig really struggles, Running with medium settings in 800x600 its really stuttery... was expecting this rig to be able to run it fine.
Checking in task manager the processer is under 100% usage.....
My old-old rig, a Palimno 2100, would run UT2004 fine, albeit with a better graphics card (rest of spec identical), but also on much higher settings....
In short is there something wrong here???
If yes, is the power supply the suspect ? (planning on replacing it anyway)
Cheers ;)
PinkFloyd
Superpi looks fine, check your Hdd is in DMA mode and not PIO (check the IDE controller in control panel -> system -> hardware -> device manager.
What drive is it?
Have you got the Nvidia motherboard drivers installed?
Take it this is the cpu you bought off me?
I had 200*11.5 @ 2.3ghz @ 2-2-2-6 also and got 44secs
That was on XP
That was on XP
Yeh thats the one.
My Super PI time sounds about right then. I've done 200x10 and that was 55 seconds. Will be aiming for 45 seconds then :)
Still no idea what is causing the stuttering problem in UT, hopefully should be getting a decent psu for it soon. and will reinstall on a better drive If I can get hold of one on the cheap.
ps, thanks for the trust Xplo :cool:
