oleaut32.dll issue when installing applications
12 Jan 2006
UK
Hi
I have having an issue with Windows 7 SP1.
When I go to install some applications they refuse to install due to the following error:
"The file c:\windows\system32\oleaut32.dll could not be opened. Please check that your disk is not full and that you have access to the destination directory"
I fully wiped the machine and installed Windows 7 without the SP1, to see if it was SP1 causing the issue and found that all the applications that wouldn't install, installed just fine.
As soon as i applied the SP1 update nothing would install.
Has anyone came across this file causing problems?
