Olivetti ANK 27-102 N
Pull off a keycap and check if you want to be sure.
From what I can find out on Google the 25-102 seemed to of had rubber domes (So not mechanical) but other models from the same manufacturer used different types of switches so it could be anybodies guess.
It says it is mechanical, and has seperate keyswitches
E: I have not got it yet, on a bid from 1993 or something, check your emails
