Olympic Weights
20 Mar 2007
Norwich
I have an olympic barbell and the following plates:
4 x 1.25kg
4 x 2.5kg
4 x 5kg
2 x 10kg
2 x 15kg
Anybody know a good (cheap) source for olypmic discs? I'd like to get a couple of 15, 20 or 25kg rubber coated ones ideally but they all seem ridiculously expensive, even the normal cast iron plates.
I dont believe you can buy cheap 15/20Kg plates at all....ive looked a lot already. If you do find some....point me the way:)
I was wanting to buy a couple of 10's and 15's at least....but I reconned Id be beter off buying a full 100kG set with bar.
