- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi there!
Here are the main improvements of the new three hundred two against the older classic three hundred. (Stock arrives the end of Feb!)
• Supports graphics cards up to 12.5” (318 mm) long
• Enlarged CPU cutout / fan mount behind motherboard tray
• Fits Kuhler H2O liquid coolers
• 11 total drive bays (5.25” and 3.5” tool-less)
• Cable routing holes
• Perforated front bezel
• 120mm side intake fan (Optional)
• 8 expansion slots
• Tool-less HDD drive bays
Antec 302 Three Hundred Two Ultimate Gaming Case - Black @ £64.99 inc VAT
The team that brought you the Three Hundred is back with an enclosure designed to handle today and tomorrow's high-performance systems. Introducing the Three Hundred Two, the next standard in affordable gaming cases. Our newest chassis is built for gamers from the inside-out, from its aggressive front bezel, to its advanced cooling system. With tool-less 5.25" & 3.5" drive bays, a large cable management compartment and two front panel USB 3.0 ports with an internal connector, the Three Hundred Two is the rightful heir to the Gaming Series legacy.
- 11 drive bays:
- 3 x 5,25" tool-less drive bays
- 2 x 2,5" drive bays (dedicated)
- 6 x 3,5" tool-less drive bays
- Motherboards: Standard ATX, microATX, Mini-ITX
- 8 expansion slots
- Maximum graphics card size: 318 mm (12,5")
- Maximum CPU cooler height: 170 mm (6,7")
- Rear Cooling: 1 x 120 mm rear TwoCool fan
- Top Cooling: 1 x 140 mm top TwoCool fan
- Front Cooling: 2 x 120 mm front intake fans (optional)
- Side Cooling: 1 x 120 mm side intake fan (optional)
- 1 x 120 mm side exhaust fan behind motherboard (optional)
- Perforated front bezel for maximum air intake
- Water cooling support: top water cooling grommets
- Enlarged CPU cutout
- Front I/O ports: 2 x USB 3.0 with internal motherboard connector / Audio In/Out
- Unit Dimensions: 513 mm (H) x 229 mm (W) x 471 mm (D)
Only £64.99 inc VAT.
ORDER NOW
• 8 expansion slots
- 11 drive bays:
- 8 expansion slots
ORDER NOW
