OMV KVM connection issue
10 Sep 2009
United Kingdom
I made a VM to host Home Assistant on OMV using KVM. I can ping the VM's IP address, but I couldn't connect to it, and the Home Assistant could detect it as a server.
I go the IP from the details button of the VM in OMV web UI
I set the VM's network to use the mactap network to the network adaptor. I am not sure what I am going wrong (or right) here.
I remade the VM and I can't even connect to the web interface using http://homeassistant.local:8123/ anymore.
Another question is can I make the VM's IP static?
Edit:
I redo everything the same way and somehow it worked and I can find the home assistant VM using its IP. But I still don't know how to make sure the IP is static
