Good Morning fellow overclockers.
I've had some random inspiration to reduce the temperature and noise of some of my components, namely the CPU and Graphics card. My specs are as follows:
i7 920 (original stepping, got it last year when it was new)
6GB DDR3 NQ PC3-12800C9 1600MHz (3x2GB) Triple Channel DDR3
Powercolor ATI Radeon HD 4870 X2 2048MB
Gigabyte GA-EX58-UD5
rest is irrelevant..
To obtain my goals I have acquired the following:
1x Noctua NH-U12P SE2 Dual Fan - http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-NC
1x beast of a 4870x2 cooler - http://www.arctic-cooling.com/catalog/product_info.php?cPath=2_&mID=244
1x Arctic Cooling 4g MX-3 thermal compound.
The last time I overclocked was when I had a Athlon XP Barton core CPU, so I'm a little out of date. I've had a quick look at the overclocking sickies, so I've got a basic understanding of the process, but I have a few questions regarding specifically the i7:
1. Is there anything I can buy from a general supermarket (tesco etc) that can remove the thermal paste currently on my CPU?
2. How much thermal paste should I put on?
3. What is the technique on applying thermal paste? ie is it best to spread a rice sized drop spread across the cpu, or place a bit in the middle and then put on the heat sink.
4. Any specific cpu/ram voltage settings anyone can recommend (i've seen some for the d0 setting, but not my one).
Thanks for your time, I look forward to posting some results/pics. I have a target of 3.2Ghz.
