I have HP small form factor PC with on board sound. I had my music on pretty loud the other day and could hear crackling, I had the "In Windows" volume turned up to full.
I turned down the "In Windows" volume down a little and it seemed the crackling went away a tad.
What kind of setup do you use with volume? And should I really buy a PCI sound card to improve sound??
Can anyone recommend a really cheap sound card?
Thanks
Thanks
