On demand AV scanner
3 Apr 2007
South of the Watford Gap!
Is there such a thing as an AV scanner that only runs when I want it to? So it's not actually installed as such, doesn't run or use any processes, I'd manually update signatures and then initiate a scan manually when I wanted it to check the PC out.
Online scanners from kaspersky, or norton, or panda do this sort of thing.
Unsure how good they are, would need a net connection.
Mse very small footprint, shouldn't slow you down.
Microsoft Safety Scanner, DrWeb Cure It, Hitman Pro, Malwarbytes only ones i usebut you could always install a antivirus and just turn off real-time and use it as on-demand, quite a few people do this with Avira & Microsoft security essetials.
