- 10 Jun 2010
- Scotland
Is it possible to use onboard graphics with the ASus 68 boards at the same time as an hd5450? My goal is to drive 3 monitors.
Yes, but not a stretched gaming display.
A Z68 motherboard can drive upto two screens, what board do you have?
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
So you can use the DVI+VGA ports on the board.
Then the 5450 can connect to the other via DVI
In "advanced bios features" on my gigabyte board there is onboard gfx options of,
auto
enable
enable if no PEG (no gfx card)
So you enable it, install the intel HD drivers and you go from there.
even Google brings up a zillion answers - https://www.google.co.uk/search?cli...,cf.osb&fp=ce29245d43c22910&biw=1920&bih=1117
