Onboard graphics + 24" screen: will it work?
Err, it might do. It might not.
Depends on the the resolution you want to run, and the resolution of the monitor. We have a SFF box that runs 1280x1024 max. That will look pants on a 24" monitor.
What is the max supported resolution for the 630i you have?
Why not get a gfx card that will make your 24 incher look good. Honestly I would be amazed if it could run anything above 720p media.
I'm using 630i integrated graphics with a Dell 2408 (as a temporary solution). The Aero interface in Windows 7 is slow so I would not recommend this as a long term solution. I can however play 1080p mkv files without any problems.
A newer 730i or G4x motherboard would probably be much faster but for that additional cost, you could buy something like a radeon 3650 which is still quite power efficient and much faster.
