Onboard graphics and GPU
17 Dec 2009
I bought an MSI B450-A Pro for my build. The reason I bought this motherboard rather than the tomahawk was that it has a VGA output; retro I know.
I've always liked a square monitor as my secondary monitor. I just feel it's better for reading PDFS and such when I'm doing my uniwork. I often move stuff over to my square monitor for reading as I just find the size feels more close up/proportionate and I've never wished to change to 2 16:9 screens.
Only problem now is most GPUS dont support anything but digital outputs, and I always got away for years with a VGA - DVI-I adapter. Now it's all DVi, HDMI and DVI-D, I wasn't aware you could actually get converters to scale down HDMI/DVI to VGA.
These adapters are pretty cheap, but the fact I've chose a cheaper board for a specific reason to use to power my VGA monitor, is there anyway I can actually get it to run off my mobo when my graphics card will be powering my mainso I don't feel too gutted I've bought a cheaper board for no reason.
My CPU is a Ryzen 7 1800x, I've read mixed reports it can't process onboard graphics; is this true? Didn't realise the CPU had so much influence on onboard graphics.
Would a motherboard flash maybe support my request as it does say something about integrated graphics on my BIOS but doesn't let me chose anything
Many thanks
Jonathan
You're right the cpu has no internal gpu so any output from the mobo will not work.
With HDMI > VGA you'll need an active adapter with changes the signal from digital to analogue.
