- 21 Oct 2012
ive finanlly decided what im going to do about a new pc for my missus and that is to buy new and buy one of them barebones from this site that only require Ram and HDD(maybe CPU) and have it as a xmas present which i think can be financially possible.. could buy used for less and probably use bits from her N1, but ideally want the option of 4gb plus..
on the basis the 250gb sata HDD my missus has with XP HP SP1 on it is compatible then i would only be looking at a 2nd but larger HDD and use 2gb of fast Ram(max being 8-32)) to get her going then upgrade to more and win7 64bit..
now the actual question in hand is, the onboard graphics on some of the kits sound really good, but what i want to know is despite being newer and onboard, are they better than a Geforce 8500GT 256mb? as if they are then i can hold out for a GPU at a later date.
Kits as followed
Ram HDD CPU required)
http://www.overclockers.co.uk/showproduct.php?prodid=FS-278-OK&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=FS-268-OK&groupid=43&catid=2385&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=FS-266-OK&groupid=43&catid=2385&subcat=
(HDD required)
http://www.overclockers.co.uk/showproduct.php?prodid=FS-298-OK&groupid=43&catid=2385&subcat=
now as i looked up, that last one i linked is basically what i want to achieve lol, but now wondering if i could do better for similar price using one of the other kits?
so yeah basically are the onboard Graphics for each of those better than the 8500GT?
think thats all i was planning on asking, so thanks for reading.
Kits as followed
Ram HDD CPU required)http://www.overclockers.co.uk/showproduct.php?prodid=FS-278-OK&tool=3
(HDD required)
, that would be more than capable of what she wants and at a very good price compared to other less specced systems for more, so gives me the chance to save up, that is unless i can get lucky and buy a cheapo but good laptop for 100 and put the rest towards the desktop and do both ha.
