Onboard Network Card
29 Dec 2007
Birmingham
Hey Guys,
Ive had this build for a little while now and im having a small problem.
The motherboard i have is Asus p5kc combo with integrated LAN the only issue is it wont work.
Ive installed all the drivers enabled it in the bios etc and its not having any of it.
The network card installs but when i plug my lan cable into it just says "Cable Unplugged" well something along those lines.
Im using my realtek network card at the moment so i can use the internet but it would be a lot easier if i could use the one integrated :)
Cheers for looking
SS btw - http://i29.tinypic.com/242fzhw.jpg
