- 28 Jun 2006
- Newcastle upon Tyne
Not sure if this should go here or in the Sound section, but my microphone does not work with my DS3. I've tried both front and back plugs, but it wasn't quite as straight-forward as NEVER works.....here's some info.......
My mic works fine on my second machine.
I plug it into the back - no go. I plug it into the front audio connector (PC7) and it didn't work (Teamspeak or Windows voice thingy). I'm using on board audio, by the way. I open up the Realtek software and go into the bit where you configure your mic - it can hear me - hallelujah! Back out, nothing else can hear me......so it's just Realtek software......so, really, maybe this should go in Sound......
*quick cut and paste*
Thanks for any advice you can offer! (apart from go buy a soundcard
Skid
)Skid
