I have an old s478 P4 setup which used to house my emu 0404 until I moved it into my rig. I didn't uninstall it properly I just removed it. Afterwards the onboard sound didn't seem to work then I remembered to uninstall the drivers. One problem they wouldn't uninstall because the card wasn't present so I proceeded to delete them and then remove the entry from the add remove programs list using tune up utilities.
The onboard sound was never disabled because I never had any confilcts but I checked in the BIOs and it's been on the auto setting since. I also instaled the right AC97 driver for my aopen ax4pe max.
It appears in the sound properties and in foobar but no sound will come out of the speakers.
