Onboard Sounds vs a card?
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey
I am just wondering if its worth me gettign a soundcard.
MY quality of sound from my onboard is fine,
I'm using a set of creative speakers SBS 380's, only cheapy ones. aprox £25
Well what I'm wondering, is what kind of CPU reduced usage using a dedicated soundcard give me.
At the mo, playing an MP3 gives me around 7-11% CPU usage.
Would that drop ?
If you ar using XP then i'd definately recomend getting and XF-i especially if you play games, heard there's problems with vista and sound cards so i couldn't say about that.
I was going to ask the same thing. whether or not to steal the Audigy(I think its the 1st one) out of the old pc before i sell it. Ill just do it and stop being lazy. I would be interested if there were any figures though.
I have Vista 32bit, and I don't find any problems.
Except in wow, the channels defaults back to min each log on!
Well my X-fi Xtremem Gamer card even showed my crappy hi fi speakers how to make things sound better. On my Gigaworks S750 it is mind blowing. I play a lot of music as well as play the Keyboard/Piano and the card brings sounds to life over onboard from my experience. I haven't tried the onboard sound on this motherboard but my last board was an Ultra-D from DFI and the sound difference was noticible as I had both the onboard enabled and the X-fi. A quick change between the two and trying the same song showed it easily. Even with the X-fi you do hear instruments and sounds that didn't seem to be there before.
Another vote for an external card, not saying the x-fi are the best but thats what i have and it sounds great
While pretty much everyone is going to agree that sound quality will be better on a dedicated sound card (with decent speakers/headphones), the question was really:
It depends on a few things, like the sound chip, drivers and operating system. I think the kind of CPU usage you see is symptomatic of a sound chip lacking a digital signal processor so it has to use the CPU for decoding and encoding sound - a dedicated card would take this work and offload the CPU.
The M2N4SLI uses the Realtek ALC850 6-channel AC '97 audio chip, so it sounds (no pun intended) plausible that a sound card will free up the CPU for you.
