http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0008.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0009.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0010.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0011.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0007.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0013.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0014.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0015.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0016.jpg
http://www.ghdtradezone.com/images/FBPic/GHD_Hair_Straighteners_0017.jpg
Graphics core
Graphics chip: parameter error correction Radeon HD 5770
Chip manufacturers: ATI correction parameters
Manufacturing Process: 40 nm correction parameters
Core code: parameter error correction RV840
Card frequency
Core frequency: 900MHz correction parameters
Memory Frequency: 5000MHz correction parameters
Memory Specifications
Memory Type: GDDR5 correction parameters
Memory capacity (MB): parameter error correction 1024
Memory Interface: 128bit correction parameters
Memory Description: parameter error correction using 0.4ns GDDR5 memory
Memory Speed: parameter error correction 0.4ns
The maximum resolution: 2560 * 1600 correction parameters
Graphics card cooling
Cooling: parameter error correction cooling fan
Graphics Interface
Bus Interface: PCI Express 2.0 16X parameter correction
Input / output interface: HDMI error correction parameters
Display interface: parameter error correction 24-pin DVI-I interface / 15-pin D-type (VGA) Interface
External power supply interface: parameter error correction 6PIN
Physical Characteristics
3D API: DirectX 11 parameter correction
SP cells: parameter error correction 800
