I'm hunting for a solution to have two ARC devices (TV and projector) connected via what i hope will be a HDMI switch to my AVR's output 1 which supports ARC.
I want to switch between either the TV (4K120) or projector (4K120 or FHD240) and get the Atmos audio from both using TV Audio (ARC) on the AVR. My main gaming rig is connected to the projector because i want either 120 or 240 output direct to it and my AVR only supports 4K60 plus it would be a nightmare to cable up to. Both devices output DV / Atmos from the native apps and I just want the AVR processing the sound depending which i'm watching. At the moment i physically swap the AVR output between the two respective HDMI cables from each device and independently it works perfectly. I want to cut out that manual swapping of cables though.
I've tried a few bi-directional switchers without success and want to avoid audio extraction via optical because of the downgrade in audio signal away from Atmos.
Apart from upgrading the AVR and cabling more things back to it, is there a fesible solution to switch between the ARC devices retaining Atmos from both?
