Hi All
Just wondering if I could have some advice from the forum? I have 2 x GTX780's in SLI and have just noticed that one of them is running at 60C idle while the other runs at a more reasonable 34C. Fans are both running but with the hotter cards fan running approx. 300RPM quicker.
Should I remove the heat sink and replace the thermal paste or would a replacement heat sink / fan be in order?
Any and all suggestions welcome.
Cheers
Cheers
