One core 20c hotter than others on idle.
28 Jan 2018
Just after some help.
I have a delidded 8700k which i got from overclockers about 3 years ago. It was a binned cpu which they added liquid metal under the ihs.
Everything has been rock solid until the other day where i noticed one of my cores is 20c hotter than the others on idle!
I stripped it down and replaced the LM with thermal grizzly stuff. And did new tm for the waterblock etc. But its made no difference.
Is that supposed to happen? Its odd that it just happened out of the blue?
On idle it is 20c hotter but on load it is about 9c hotter
Edit:
Im also now getting bsod when running prime on my 5ghz overclock?
Is this the sign of a failing chip? I was using 1.335vcore for 5ghz and o have tried bumping it up a little but still getting errors in prime and bsods.
