Hey. I'm trying to decide between two options for airflow in my case.
I'm inclined to go with
Two fans on a 120 radiator, intake, bottom front of case
One fan on a 120 radiator, exhaust, rear of case
PSU, exhaust, top rear of case
Two fans on a 240 radiator, exhaust, top of case, at the front
The issue here is that there are few (aiming for zero) holes for air to be drawn in through. I don't know what the effect of this will be, anyone more experienced care to guess?
Its convenient in terms of preventing dust getting in. The other obvious option is to reverse the fans on the top, which will make maintenance harder, or to leave some holes in the case for air to get in through near the top of the front of the case. Hopefully I've been clear enough, photos will turn up in the future if need be. Cheers
Done my best with test runs, but it's tricky without installing components in the case. With radiators and fans installed, with the negative pressure set up, lots of cold air comes out the top. This is without psu and the pci covers removed, so it's likely that air is moving in through these. I guess I'm hoping that fan rad fan moves air through the radiator significantly faster than one fan per rad.
