ok i just put heatspreaders on my ram sticks , now all of a sudden a my screen is not appearing on boot. it worked a few times and then didnt a few others....i fiddled around with the ram thinking that was the issue til i realised they were both in correctly and very hot....i check on a mates computer the code for the beeps and it says video problem. i figured my 9600 pro had died so took it out and plugged my monitor into the onboard graphics and still nothing but the same beeps!! whats going on. i did install the ram the wrong way around at first and the computer showed only 512 on boot instead of 1204 so i turned off and fixed that but the screen was working then. does anyone have any ideas or no what to do?
